transformers | on ElectriciansForums
Discuss transformers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
parker3074
hi
currently doing transformers
and has anyone got a chart/method
working out the turns ratio and current on each side
thanks
you have actually answered your own question. Turns ratio.
Number of turns in Number of turns out Vp/Np = Vs/Ns. You will need to manipulate the equation to meet youe specific requirements.
ie. Ns= Np x Vs
Vp
Single phase is straight forward! Ratios are constant.
Three phase you need to take into consideration the transformer IE:
DELTA : DELTA
DELTA: STAR
STAR : DELTA.......ETC ETC.
Line and phase values differ. Ratios differ.
example:
Delta secondary.....Line value = Phase value.
Star secondary......Line value = phase value x root3.
Thats why I asked.
Cheers
Yes!!! Thats why I have tried to explain how they can change so that no one freaks out when it happens!!!
Its all a conspiracy!!!
Cheers
Reply to transformers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Interesting. Sounds unusual since it seems it was very lightly loaded. Not much you can do I suppose other than buy a replacement unit. Unless...
I have a 13v AC transformer, to which wire numbers should I connect it to without destroying the windings. This was an old arc welder with a...
