Transmille 2080s for sale | on ElectriciansForums
Discuss Transmille 2080s for sale in the For Sale and Wanted Forum area at ElectriciansForums.net
M
montrano
Brand new Transmille 2080 check boxes.
ÂŁ140 each.
Can post in UK for ÂŁ5 each.
4 available at present, offers considered for multiple purchases.
Spec as follows;
Designed with low cost and portability in mind, the use of the 2080 provides on or off site verification of RCD Testers, LOOP Testers, Continuity and Insulation Testers.
The 2080 is simple to use and provides the following functionality:
Checking of Insulation Testers
• 3 high value resistors (1M Ohms, 9.9M Ohms & 99M Ohms) for testing the resistance measurement function.
• LED indication of test voltage at 100V • 250V • 500V • 1000V
• 3 low value resistors ( 0.5 Ohms, 2 Ohms & 10 Ohms) for testing the continuity function.
• AC line voltage output for testing voltage measurement
Checking of RCD Testers
• Dedicated 13A socket provides functional check of RCD tester operation
• 3 selectable ranges : 10mA@150ms • 30mA@150ms • 150mA@30ms
• Indicators for Ready • Tripped • Overcurrent
Checking of LOOP Testers
A functional check of LOOP Testers, allowing direct measurement of supplied loop impedance and supplied loop impedance + 1 Ohm via a dedicated 13A socket.
Wiring Check
When connected, the 2080 checkbox will indicate voltage between the following wires *
P-E (Phase to Earth) • P-N (Phase to Neutral) • N-E (Neutral to Earth)
* Does not detect Neutral to Earth reversal​
Reply to Transmille 2080s for sale in the For Sale and Wanted Forum area at ElectriciansForums.net
Just thinking about selling MFT's and single test equipment. The idea being I buy stuff from Ebay and sell it on ebay, which I am doing at the...
Thanks again, I’m sure I’ll be back with many more questions
