Transpositon of eaths. | on ElectriciansForums
Discuss Transpositon of eaths. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
scotsparky
Glasgow
Hi folks i have just tested a saw mill and the earths have be transposed from the main building to the sheds with no rods in place.
Any idea what the reg is which says a rod has to be fitted?
Without any info we can't reply ....
What is the nature of the supply system?
What size earthing?
come on scotch you know better than to just ask a blank question!
Depends what size the 4 core SWA cables are, and if there is any extraneous earthed metalwork within these sheds...
Extending a TNC-S/PME equipotential zone is not in itself against any regulations...
What is the size of the incoming supply this will determine the requirements for equip' bonding thus the options you have if your 16mm isn't sufficient.
Explain your comment please.... We are not allowed to create or extend a PME set-up thus im confused by your comment?
DNO's will often allow a single supply to be distributed between large metal units, its where there is more than one supply, diverted neutral currents from several supply's may become problematic.
Probably not relevant to the op, just an of the cuff remark.
Chris
Reply to Transpositon of eaths. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
