tray and conduit | on ElectriciansForums
Discuss tray and conduit in the Talk Electrician area at ElectriciansForums.net
T
tomasi
:) are there any sites out there showing how to fabricate
cable tray/conduit as my nephew is keen to learn as
he is starting college soon
considering the sparks i work with it feels like a dying art ,these days people are too quick to use manufactured bends pity i cant draw on this puter
Im not sure if you can learn how to install tray and conduit from a web site or even a book for that matter,
The way to learn,as with all practical skills, is by doing it .
the best thing your nephew can do is to wait untill he gers to college,and then hopefully gets a job where he can learn on site,
good luck
As above.
I've been learning dog legs, 45, 90 bends in trunking, tray and basket etc.
Bloody hell. There'll be a course on that too soon!
Rum and Wayne are right this is a dying art the only way to learn is by being shown although one thing I can explain is we used to mark the conduit former 1 1/2 inches from the back this would give you the back of the bend. So for sake of argument if you have from the top of a box to the ceiling 500mm measure 500 mark with a pencil put the pencil mark on the mark on the former then bend to a 90 degree making sure that the measured length is facing you. Give it a go and once you get the hang of knowing where the bend starts and finishes you will be able to do all sorts of bends. Understanding the bender is the key. As for tray one method is measure from A to B then mark a line across the tray then measure to one side what the width of the tray is, lets say the tray is 4 inches mark 4 inches from B making C lets say, mark a line from B to C across the tray. Cut this triangle out then bend your tray round until both sides meet mark the lip where it touches or you have 90 degrees then cut that lip off. Once that is done fold the tray back round and bolt together. This is for tray fixed on one surface and you must check which way you are bending, left or right and the position whether it is on the floor or the ceiling because it will be transposed. Again give it a go many sparks have different methods and some like to show off their prowess on bending tray ,trunking and tube so don't be frightened to ask. I could explain trunking as well but this post is long enough already! I hope this has helped.
Reply to tray and conduit in the Talk Electrician area at ElectriciansForums.net
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
As above, you really should be capable of dead testing first, as 230V is quite capable of killing or causing bad burns, etc. If you are thinking...
