Triangle screw heads | on ElectriciansForums
Discuss Triangle screw heads in the Electrical Tools and Products area at ElectriciansForums.net
I have been asked to do a job on some external light fittings that have screws with triangular heads.
Does anyone know where I can find a tool to remove these screws, I had a go with my pointy nose pliers but it's proving very difficult.
All help appreciated.
There's so many different configurations, some have a pin in the middle, some have one offset side. I would use google images to find the exact one. Once you have the correct terminology or name then use google web search.
Thorn have a habit of using these stupid things, all their fittings come with a cheaply made key, i have a couple kept in the toolbox along with many various EM light keys/fire alarm etc...
Are the lights being replaced or just a lamp change?
if replaced id just smash the fronts off
Reply to Triangle screw heads in the Electrical Tools and Products area at ElectriciansForums.net
This is an RSS feed of thread: Pura shower head - too much weight for a tiny thread Content of the thread: Hi there, Hopefully someone will be...
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
