Tricks for pulling wires | Page 3 | on ElectriciansForums
Discuss Tricks for pulling wires in the UK Electrical Forum area at ElectriciansForums.net
M
Mixmaker
Hello guys! I am a bit stuck with pulling wires through the wall. I am pulling new electrical cable to next room, cable are running behind ceiling plaster board, issue i am getting is that when i pull wire in the same route with other electrical wire, cable pulling rods hitting brick wall.What i have realised is that the cable route is "'snaky".What i mean is snaky: drilled holes in wood and wall are not on same way, one drilled hole 1 cm out.Could anybody tell me is there any tricks to pull this electrical cable?I know this cable has been pulled as new installation when house was already build.
Kind Regards!
Easier to make a hole in ceiling and make good than take up a carpet or laminate. Biggest obstacle is explaining to the customer that you know what you are doing! "Trust me"
Reply to Tricks for pulling wires in the UK Electrical Forum area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
"Value engineering."
2 3
5K
