A
alanl
Went to visit a close friend yesterday. They said they'd had a bit of electric work done, and he was really cheap.
New light pull switch and new pendant as a like for like, then, a double outside socket put in. ÂŁ85 complete.
As you can imagine, I was a bit wary when I heard the price. I knew the house, and it is on 3036 fuses, with inadequate bonding (4mm unsheathed main earth etc).
He has taken a feed from the kitchen circuit, ran it in 2.5mm T+E under the decking, then fitted an IP44 double socket outside. No RCD, no new bonding, and obviously, no certificate.
Making my blood boil, he signed his quote as 'Steve *****, Electrician.'
Now, to my mind, this bloke should be challenged about his unsafe install, but, I'm in a bad situation where I cannot get the homeowner to complain, as she is oblivious to the danger, and that, although he was cheap, she has been ripped off.
Any advice?
Ta
Alan.
Any advice?
Ta
Alan.
