david0173
Hi All .A little advice if you please.Called to a tripped not resetting rcd tonight.The owner said that its been tripping for ages but they have just been resetting it now it wont.
On looking at the C.U.the RCD protecting two mcbs all wiring to rcd and circuits looks ok and tight. i switched off all the mcbs and then the board.switched main back on the mcbs on non protected side all good so far.tried to switch on RCD but wont switch on you get the green in window and as you move the switch up it changes to red but wont stay on this is without any load applied.left the rcd side all off only lights tonight.
Going back in the morning ,any thoughts would be great thanks
