Tripping next doors RCD | on ElectriciansForums
Discuss Tripping next doors RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bgec
Hi to all The other day I found the fault on a ring main this was repaired and when I was testing the circuit (RCD Test) the neighbour came over and said that his RCD kept tripping I was confused When I tripped the RCD in the house with the test it tripped next door at the same time to me that is wrong
I will be honest I have not much experience with TT systems and this is a new one on me too
Thanks Guys
Hey.
This sounds really quite serious, I would get on to looking at this ASAP perhaps a call to youe DNO may be in order too. From what your saying any fault current that originated in one property could transfer to the other one and if bonding isn't up to scratch the someone may get hurt!!
Cheers.
Reply to Tripping next doors RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this...
