R
Rambler1
Hi All,
I've got a 63A 30ma RCD in my garage / workshop which keeps tripping. The regular load on it is a standard domestic chest freezer with a 45W pond pump on a timer. The timer is set to switchthe pump on and off 6 times per 24hrs, each run period is 1.5hrs and they are equally spaced.
I have noticed that A) it doesn't trip during the frosty weather but now that its warming up it has started tripping again about once a month, later when it gets warmer it can trip as much as every day but not all the time, sometimes it will go for a week and then trip 2 / 3 times in a day. B) When I've been around to actually see/hear it trip I've noticed that it appears to do it on the power off part of the cycle.
If it was a dodgy connection or insulation I would have expected it to trip on the power on part of the cycle. I had a 60W pump on it and I changed for the smaller one but it made no difference. I've also checked all the connections but they seem ok. The cable on the pump is the original as supplied with it. I've isolated the freezer so that only the pump is on the circuit but it still tripped. I also changed the origional electronic/digital timer for an electro- mechanical cam type but its still the same. The pump is protected by a 5 amp line fuse which has never blown.
Any good ideas as to what it might be????
