Triton shower isolator switch | on ElectriciansForums
Discuss Triton shower isolator switch in the DIY Electrical Advice area at ElectriciansForums.net
Bristol, Bristol
I have an 8.5kw Triton Excite Plus shower, could there be a reason that it has been installed with a 50amp isolator switch, & not 40amp which Google suggests would be the compatible for a 8.5kw shower ?
8.5kw will will draw approximately 37A therefore your isolator needs to be the equivalent or preferably above hence 40A, a 50A isolator is actually better.
Reactions: DPG
Reply to Triton shower isolator switch in the DIY Electrical Advice area at ElectriciansForums.net
RCD it up for the effort it would take I would suggest. Look at the EV fiasco starting to take shape where no RCDs have been fitted and now...
https://www.electriciansforums.net/threads/mira-shower.194527/#post-1708398 See post #9 🤔 but now I see it didn't seem to work for the OP! Also...
