Triton T80xr | on ElectriciansForums
Discuss Triton T80xr in the Electrical Tools and Products area at ElectriciansForums.net
J
jmeservices
have come across a few of these shower burning out the inlet terminal lately has anybody else come across this just wondering if this is a common fault with the T80xr. this is the only triton model i have seen with this problem here's a picture
[ElectriciansForums.net] Triton T80xr
It's not a fault specific to the Triton TX80XR mate. We see this type of damage, due to poor cable termination, across a wide spectrum of modern shower units. The higher the power of the shower unit the greater the risk of termination issues.
In the not so distant past, manufacturers used porcelain terminal blocks with double screw terminals each side and this type of damage was rare event; retrograde progress not confined to shower units, it's common in modern consumer units where single screw terminals are also the norm!
Reply to Triton T80xr in the Electrical Tools and Products area at ElectriciansForums.net
You could compare the resistance of the coil of each (e.g. using a multimeter - though with the relays in circuit with their drivers you might get...
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
