Trouble shooting? | on ElectriciansForums
Discuss Trouble shooting? in the UK Electrical Forum area at ElectriciansForums.net
F
FrankUK
I do a lot of commissioning and trouble shooting for a well known name of ventilation/heat recovery equipment, and I was tasked to have a look at a problem in Bournemouth today, where the fault was reported as an electrical heater 'overheat' problem.
The ventilation unit has an inbuilt supply fan and extract fan, heat exchanger and electric heater battery. The unit is 3 phase with inbuilt controller.
Here's the pictures of what I found. The additional wire terminals (not the manufacturers grey ones) have been fitted by the installing electrician, who has taken a supply to feed the orange relay which switches the additional ventilation fans on when the unit is running.
K1 is the contactor for the supply fan on full speed
Anyone spot what has happened?
[ElectriciansForums.net] Trouble shooting?
Are you asking us about your fault or all the other issues i can see ?
Overload protection for motors.
Screening on SY not earth (if carrying low voltage)
The complete mess of a job in the control box
The drawing asks for a 10a breaker and that's what is installed. The only thing I could see that could perhaps be different is that you may want a D type breaker if you have startup current of two fans but the size if the fans isn't states..
I'm stuck!
All overload protection is in place.
All wires, SY or other is correctly installed and earthed.
The problem being investigated was why the electric heater overheated, shutting the unit down on fault.
The manufacturers wiring has been altered by the installing electrician
The additional fan relay (orange one) has a trigger input (B1)
Right im with you well in that case unless the fan is on full speed the additional fans wont operate.... other than that its still poor workmanship... its just hard to jump between your write up and the picture which is just a mess of cables.
Its not too easy to spot has we have a partial wiring plan and we don't know how the set up works where-as you will be familiar with it, i would have needed a full wiring plan to work out how the system functioned to jump in quicker with an answer....
Either way the original control board including the dodgy additions is poor workmanship looks like it was made up by a domestic sparky out of his comfort zone
I'll leave it a couple of days before I explain what has gone wrong, to give others not on line at the moment the chance to have a look at the information.
All the clues are there though.....
Reply to Trouble shooting? in the UK Electrical Forum area at ElectriciansForums.net
