Hi all
Bit of advice needed. Got called to a job with a bunch of lights not coming on the set up is a 5 way board controlled via a timeclock and double pole contactor also has a small fuse inside of enclosure which is plug in fused wire type if you look closely at picture any ideas what could be for maybe protect the coil.
The contactor has failed and is jammed hence reason lights not working ,
Now the problem the contactor in question has been discontinued looks ancient i enclose pictures.
I now have a up to date contactor to do the job, being my first time wiring from an old version im very confused on connections of old to new, again picture will explain.
Now i have a1 a2 12 top 34 bottom, would i be right in saying that sw live from my timeclock goes to a1 of contactor a2 being neutral and 1 supply in 2 load to 5 way board..
Any advice appreciated,, i know sounds basic but thought id ask. Also i enclose pic of new contactor Regards johnny
