<div class="bbWrapper">As I tried to summarize in the title, I'm having an interesting buzzing issue in a residential home.<br />
<br />
Problem: When Lights are turned on, all 3 switches controlling the same load start to buzz, as well as the breaker the lighting circuit is on. Buzzing stops on all devices and the breaker when the lights are turned off.<br />
<br />
Facts Worth mentioning:<br />
<br />
<ul>
<li data-xf-list-type="ul">House was wired in 2020, so all wiring and devices are pretty much brand new</li>
<li data-xf-list-type="ul">Breaker is a 15amp Leviton Arc Fault Breaker</li>
<li data-xf-list-type="ul">Lighting load is (10) 12w LED lights, rated for dimming</li>
<li data-xf-list-type="ul">Dimmer switch is rated for 150w</li>
</ul><br />
Attempted Solutions:<br />
<br />
<ul>
<li data-xf-list-type="ul">checked connections on all switches- everything is good</li>
<li data-xf-list-type="ul">I removed the dimmer and replaced it with a normal 3-way switch, when I turned on the lights there was no buzzing.</li>
<li data-xf-list-type="ul">replaced with brand new dimmer switch, buzzing came back</li>
<li data-xf-list-type="ul">replaced the Arc Fault breaker with 2 different breakers of the same type, buzzing continued on both of them.</li>
</ul><br />
In Summary:<br />
<br />
So this is where I currently stand. I'm wondering if maybe it's an issue with the wiring in or between the lights somewhere? But when there is no dimmer in the mix there's no buzzing at all. My only idea is getting a more heavy duty dimmer that's rated to dim up to 300w LED loads, but I'm not overly convinced that will solve the issue. Just wondering if anyone has encountered this kind of issue before or has some other solutions I haven't tried yet.</div>
