Robin M
I'm new here so I hope I'm posting in the right place.
Is there any way to control and sync two separate lights to come on triggered from either of two PIRs? Maybe RF?
I have an outside path & steps leading up from garage to house - going round a corner -- which needs lights at both ends. Currently I have two PIR controlled spotlights , one each end, and if they are both on the lighting is fine. Trouble is that when walking down, the garage PIR triggers near the bottom when the second light is needed from halfway. Similarly on the way up. No amount of adjusting the PIRs fixes this due to the curve.
What I'd like is triggering the top sensor to switch on both lights and triggering the bottom sensor similarly to switch on both.
I'm wondering if there are any PIR lights that sync (i.e. trigger-share) via RF or something. (I'd prefer not to run another cable and would prefer to avoid installing anything halfway up). I have power both ends.
