ive got a job on at the mo that ive put a new earth stake in...the dno refused to connect pme even though its there on the grounds that its unreliable.
so my ze is now 475 ohms..
ive put in another stake on the end of a bit of 10mm and put it in the ground up to 10m away from the other stake(both connected at same time)
and i still get 370 ohms
if i run water in the stake hole i get 300.......for about half hour...then 370 again.
its an on going thing where i live its a mining area and all is made up ground.
any ideas...
ps ..i need to use this job for my yearly nic inspection.will they accept that its as good as it can get or need me to bury a big lump of metal to try and comply to 200 ohms??????
ta
vitoboy
