Stever_777
hey guys, CU change........34 OHMS ZE on TT install, with a 6 MM/SQ main earth. Do I need to upgrade to 10 or 16mm, for certificate?
Cheers
Cheers
Discuss TT install in the Australia area at ElectriciansForums.net
Cheers
stick you to remote controlled alarms
I think you meant the TT disconnection time is 0.02sif 80A fuse i think 6mm is good enough is .2 secs for tt installation
id dig a 100ft hole insert new 100mm x 10 rods or untill your rod ends up on a bbq in oz, and back fill in with magic tt dust,otherwise you will be electrocuted...if you read the other posts that is..tho its should be fine..:ninja:
So the 10 rods would add up to a meter total length, why the 100ft hole?
Reply to TT install in the Australia area at ElectriciansForums.net
