TT issues with new house | Page 2 | on ElectriciansForums
Discuss TT issues with new house in the UK Electrical Forum area at ElectriciansForums.net
Honiton, Devon
We have just moved into a house built in the 90's. So, I'm a retired electrician and was confused by the 4 x TT rods all connected within a metre of each other on one side on the house. I dont have any expensive test kit any more, but when I connected an electric fence energiser to the house earth I only got 1000v instead of the 7000+v. when I ran a test earth independent of the TT system I got the full voltage. I decided to put in a new 3/8 rod and therein lies the problem. The house is surrounded by rubble and you can hammer in a rod and then literally just pull it out again by hand. Nearest proper soil is 15m from the house. Any suggestions would be gratefully received. Ta.
Linian make some very handy accessories here. One is a rod-tip that is basically a masonry drill:
And they do a matching SDS driver to make it easier to drive in:
If you can get 8' in (two 4' rods with coupler) generally you get better results as ground tends to retain moisture lower down. However, if it really is dry rocky stuff all the way you might want to consider a trench to somewhere that has soil for a rod with better chance of success.
Thanks for your advice. will get this bit and maybe have to hunt around for some more solid ground. When I was running my electrical business I vaguely remember you used to be able to buy something like a clay to goa around the rod - will have to have a look...........
Bentonite I think it's called.
Reply to TT issues with new house in the UK Electrical Forum area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
