Tt or tncs | on ElectriciansForums
  • Thread starter carson
  • Start date
  • Replies 7
  • Views 3K
Discuss Tt or tncs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
carson
Just been to carry out a pir on a flat & the supply cable comes in line & neutral only & goes directly to the meter it then comes out of the meter to henley blocks which then supply the 2 consumer units, each consumer unit has an earth conductor connected into the henley block for the neutrals. is this wrong as i think this would tt to tncs conversion carried out on the consumer side of the supply
It sounds like a nasty DIY PME conversion.
When you say the supply goes directly to the meter, do you mean it's unfused?
I'm sorry lads maybe i should have explained it a bit better, this is a second floor flat the main 3 phase supply comes in on the ground floor to an understair cupboard it is then split up & fused & the seperate cables go up the service ducts to the individual flats, this is all done as you would expect with a 3phase & neutral supply at the origin with a seperate earth conductor coming into the main cut out enclosure which is then linked to the neutral. To me this is a typical tncs supply but after the supply cable comes into the flat i have the problem detailed in the previous post.
Well by the sounds of things and before we even go down the BS 7671-2008 road, what you have described is very much against the ESQCR-2002 statutory document and regulation 8(4) let alone our regs..
I can't remember the old Electricity Supply regulations one but a bit I do remember is that they also banned the use of TN-C within the installation.
So if that is what you have I think it may need a little remedial work.
Thanks for the replies lads the wiring installation within the flat is one of the worst i've seen e.g loop in lighting using only 2 t&e using the cpc as live conductors, no main or supplementary bonding etc etc. I've just never seen a tncs supply converted to tt by the supplier then converted back to tncs by the original installer.
Reply to Tt or tncs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
No, that is part of a different earthing system, don't mix the different earthing systems unless you have given proper engineering consideration...
davesparks
