domestic spark
When making a supply type TT what is the smallest cpc you can use from the rod to the MET thanks I'n advance. From orign to DB 25mm tails. Bs1361 type 2 main fuse. 100a
Discuss TT supply type in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is the cable going to be buried?
if you use 10mm i wouldn't worry unless you got a ridiculously low Ze and high PFC. e.g. Ze below 5ohms. PFC above 50A
well if you use a 30mA protection device, you can in effect have 1667 ohms, and it would still work! so you could in fact just place a nail in the wall with a 1mm cable attached to it! haha, it is fact, but not recommended.
Reply to TT supply type in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
