M
Mpenhallurick
Hi, just looking for someone to confirm my plan is correct for a new installation, power is coming into the building from a 25mm2 single core SWA with armour as the neutral, that goes through 80A main fuse then through the meter. As the earthing is system, would I then need to run tails through an rcd, then through the KMF before heading into the consumer unit through 3 core SWA, if this is all correct. Would my earth from the SWA connect straight onto the earth rod or would it have to go to somewhere else first.
dont do much domestic work so just wanted to clarify this was correct before carrying out work, many thanks
