steve.t.
hi
doing an extention of a tt system via a henely block, 50a fused switch, 16mm cable into a seperate cu. i want to discriminate between rcd's and cu's.
my question is do i connect the earth from the 16mm cable into a m.e.t then to earth rod, or just connect it to the fused switch or into the earth terminal in the 1st cu then to earth rod
any help would be great
