TT System | on ElectriciansForums
Discuss TT System in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
mickeymarrow
Hello All,
I am a new member with a question i hope you can help me with.
TT System, Ze test with main earth disconnected from earth bar reading = 195 ohms
Zs test on ring main reading = 0.68 ohms..!
Retested Ze but this time connected to the earth bar (main earth not connected to earth bar) = 0.15 ohms...!
Tested again, this time with gas and water bonding disconnected reading again = 0.15 ohms...!!
Question is, can parallel paths bring the value down by this degree or is this potentially a major issue?
Mickeymarrow
Hello All,
Mickeymarrow
This is absolutely normal on a TT installation, as Wirepuller said, parallel paths nearly always pull the Zs at the DB way down from the Ra value of the earth electrode.
Reply to TT System in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi Dave thanks for the info I revisited the premises to change a cooker switch and redone the test from the MET with MET disconnected from DB...
On the minor works in the brown book it has Zdb
