TT system | on ElectriciansForums
Discuss TT system in the UK Electrical Forum area at ElectriciansForums.net
B
Buzz-light-bulb
Hi all again
Just upgraded a domestic property today new consumer unit e.t.c now I've installed new earth spike with 16mm earth. Provided 30ma rcd protection for all final circuits, Ze readings are 25.2 ohms which is well below 200 ohms, Zs reAdings on final circuits are very high in the region of 30 ohms is all sounds well to me anyone else got any info to help me get better readings or should I just leave it as rcd protects up to 1667 ohms
Fair point I will investigate tomorrow as I've not done full test as yet, as it's a void property
so...if you had done the tests properly (in sequence)...then you may/will have found high values of (R1 R2)..
how come all Zs values are in the region of 30 ohms?..
get end to ends on rings for a start...then do the calc for expected (R1 R2).....
I've just re tested Ze and pfc values I got
L-e 25.2 ka 10
L-n 0.11 ka 2.2
I'm pretty sure this system may already be converted to pme but the property hasn't ever been upgraded and just requires earth conductor to connect into incoming neutral obviously I can't do that
your Zs readings should not be 5 ohms higher as the bonding will bring them down 9 parallel earth paths). as i said earlier, check at L busbar to E. internal resistance of RCDs, MCBs and main switch can affect the readings.
Reply to TT system in the UK Electrical Forum area at ElectriciansForums.net
As previously posted, almost certainly due to differences in readings obtsined with high and low current measurements on the meter, low current...
OLDBOY
O
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
