dippers
Hi all,just started using this forum,amazed theres so many people on it.
I have to change a board on a TT system(haven't done one before).
The cpc looks to be around 6mm(not sure untill i test it wether to change it to a 16mm),and has an old rccb protecting a wylex db.
Can I use a 17th dual rcd board or do I have to use a normal board with rcbo's?
Also am I right in saying that the Ze has to be below 200 ohms and the Zs for each circuit 1667 ohms.
Appreciate any advice
Thanks All
Thanks All
