tt to tncs | on ElectriciansForums
Discuss tt to tncs in the Australia area at ElectriciansForums.net
norfolk
what is the procedure for having a tt installation changed to tncs ?
who do you call billing company or dno?
also what will they want to see ?
Hi Mark,
You need to contact the DNO for this.
Basically just ask for a PME enquiry and they will book a date to come and have a look and convert if they can.
One easy way to tell before the get there, is have a look at the overhead lines.
If its a single cable entering the property then generally it can be converted.
Also, have a look along the road at every 3rd pole. if there is a cable coming down to the bottom then again, it should be ok for PME.
Reply to tt to tncs in the Australia area at ElectriciansForums.net
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
