A
amckay
Bit of advice please. I've run a 4mm t+e supply to my mums shed (4m x 2m). The shed is 3m away from the DB in the house. Supply is tncs (not sure if its been pme'd at any point, ex council house).
Now I recon I need to rod it rather than export the earth, because if the supply neutral fails and a fault occurs it will bring the real earth in the garden to 230v. (I think that's right, I don't do any theory in my job so might need a sharp reminder!)
I have never seen an earth rod before let alone installed one. I'll buy GN8 and follow that guidance, but how do you drive them into the ground? I can't expect a lump hammer would be up to the job without bending the rods!
