ringer
One of the jobs I am doing at a church is looking at tubular heaters - some of them are not working. Tubes are single or in vertical columns of three or four, running in the pews. Being in a church they are typically turned on once a week for a few hours, winter time only.
The ones that are not working show severe signs of corrosion where the flex joins the heater terminals. Where they are banked vertically, it is only the bottom one where the flex is connected where there is corrosion. Typically only one terminal is corroded, the other is fine. Wires from the flex have turned green and snapped (one terminal only), and the terminal itself has signs of corrosion too. Heaters that are still working appear to be relatively unaffected by corrosion at the terminals.
The obvious solution to this is to clean up the terminals affected, providing they are not too badly corroded, and fitting a new flex, but I would like to determine why this corrosion has occurred so that it may be prevented in future. Any advice on precautions that can be taken?
