Tumble dryer plug melted | on ElectriciansForums
Discuss Tumble dryer plug melted in the Electrical Appliances Forum area at ElectriciansForums.net
Tumsch
Scotland
My tumble dryer has been in the same position and worked for years today no power when I check plug hard to remove. Which I discovered was because melted, dryer was plugged into extension lead. What would have caused this? Do I need new dryer or can I just fit new plug? Thx
  • [ElectriciansForums.net] Tumble dryer plug melted
New plug required,
bin extension lead.
It is not a good idea to run a tumble dryer on an extension lead.
Can you get a socket fitted to plug it in to?
Was it a cheap make or well used extension lead? Contact from plug to socket is often poor and can lead to overheating.
Reply to Tumble dryer plug melted in the Electrical Appliances Forum area at ElectriciansForums.net
Thanks very much - again for your input. It is a moulded-on plug. The first thing I did was change the fuse - which looked, and no doubt (now)...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
