Can anyone recommend a tumble dryer that meets these requirements please.
Condenser location dictates non-vented, don't mind if it heat pump or not but must be able to remove condenser unit to clean as I had a heat pump one before but as the pump was attached to the condenser unit I couldn't remove the condenser to clean it out so it ended up getting smelly through the summer as it wasn't used.
NO programs just heat level and timer, I can't get on with the myriad of options they all are too hot.
Ideally pumps the water out to the drain rather than collects in a reservoir.
thanks ?
thanks ?
