Clive
Hi Guys
Can someone out there put me straight, I’ve got an old Condenser Hotpoint TDC 60N Tumble Dryer and it keeps blowing the thermostats at the back of the machine where the heating elements are and I'm trying to find out what’s causing them to blow, they are the one shot type.
I'm only guessing here but could the cause be the heating elements themselves, I have seen on a website it said for a working heater the resistance should be between 20 and 50 ohms.
Can someone tell me how to perform this test using a multimeter, I’ve included a sketch of the wiring coming from the elements plus a photo of them but I'm uncertain where I should place the test leads in order to perform the test, if someone could mark on my photo where I should place them that would be great, well at least I will be able to eliminate the heating elements.
The problem may well be the heating control module itself but at a cost of ÂŁ111.00 I want to eliminate anything else first.
There are no blockages within the condenser and the machine is clear of any fluff build up plus the door is not opened during the cycle as I know a rush of cold air into the machine can cause the stats to blow.
My thanks to anyone who can help.
