turned off lights circuit now kitchen lights won't work | on ElectriciansForums
Discuss turned off lights circuit now kitchen lights won't work in the Australia area at ElectriciansForums.net
J
joan1950
just turned off light circuit to undo some lights in lounge turned circuit back on now we have no lights in kitchen have two light switches one for ceiling haogen lights and one for cupboard lights none will work help needed
also 3 bedrooms won't work now checked whole house
so all that are working are lounge and hall and landing lights
Hi,
It seems that you may have "lost" a neutral or live to the other lighting points in the house. Is it a 3 plate wiring lighting circuit, whereby the permanent lives, neutrals and earths are in the ceiling rose or light fitting that you may have removed and not put back correctly??
Seems that may be the case.
Hope this is of some, if little help.
Regards,
Sav
at each 3plate connection there should be IN, OUT & SWITCH cables. Sounds like the power is going in but not going out hence the rest of the house not working. Unless ive misunderstood you.
Best get the candles out lol :)
check fuse or fuse wire as this sounds like the only component disturbed, when refitting fuse, inrush current may have blown it and most houses have more than one lighting circuit which would explain some lights working and others not. Iif in doubt follow above advice and get a spark
Reply to turned off lights circuit now kitchen lights won't work in the Australia area at ElectriciansForums.net
To be honest Markelect, You have had a good 25 years trouble free, I wouldn't waste any more time and effort and just go for a full replacement on...
