J
jase
have calculated mx demand to be 60A with diversity
1x32 ring
1x16 radial supply to hand 3kw hand wash unit
1x 6A lighting circuit
gonna put 63A 30mA main breaker in 5 way fuseboard fed by 10mm 2 core swa and TT it
swa run would be 35M from house.
would it be advisable to put this on an mcb in the house cu? 63 a breaker?
or which i think is better option, spilt tails in henley block, earth armoured in MET and out 63A switched fuse in?
been reading alot of posts on here and seems there are alot of 63A 30mA boards being fed by 40A mcb, how so?
1x32 ring
