tv aerial coax cable question | on ElectriciansForums
Discuss tv aerial coax cable question in the UK Electrical Forum area at ElectriciansForums.net
amlu
wild east london
hi, i got to install some tv sockets on ground floor and run the cable into the loft.
thats 2 floors up around 5 meters. can the coax cable share space in conduit with
feed for lighting on 1st floor? i mean if tv reception will not be affected?
another question- do you have any experience with those unpowered splitters?
Toolstation > Electrical > TV & Satellite > Wideband TV & Satellite Splitter
1in 2 out.
how many points can i wire using those before i will need some powered amplifier?
adam
feed for lighting on 1st floor? i mean if tv reception will not be affected? NO
1in 2 out. RUBBISH
how many points can i wire using those before i will need some powered amplifier? FIT A DISTRIBUTION AMP. IN THE ATTIC
my answers in red. just do it right.
Be careful you do not end up with multiple powered amps in series you will get a rotten signal.
If you split multiply from a dist amp then you will have a powerful enough signal to each point. If you need to split after this then you should be OK with passive splitters but they will degrade the signal.
Reply to tv aerial coax cable question in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
