Tv aerial point | on ElectriciansForums
Discuss Tv aerial point in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
G
Gerry6
Need to install a new aerial point in a conservatory can I come off an original point? I want to avoid having to run a cable all the way back to the booster in the loft.
Hi Gerry,
The answer to your question depends on the signal strength in your area.
If it is strong where you want to split your signal (after the booster) then there should be no problems with splitting the signal passively. If not, then you will need an active splitter (as you already have one with spare outputs, then that is when you need to run a cable to your loft).
As you state that you are coming out of a booster, then you should be fine to split that passively. The easiest way to do this is by buying a splitter with F-connectors on it and a pack of F-connectors. These just screw onto the cable and then into the splitter.
It may be tempting (read: cheap) to use a choc-blok or similar to make your cable. Please don't do this, as it will degrade your signal substantially.
As always, if you are going to do this by running a cable outside, use outside rated cable and an outside rated enclosure with suitable grommets for your splitter.
HTH,
Matt
Reply to Tv aerial point in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
As per James. Your aerial is now in a Faraday cage screening the signal from it. If the aerial is near to the roof insulation, you could try...
well now to throw some stuff on the tv wiring I did ages ago I have a labgear 8 port distribution amplifier mounted in the airing cupboard...
