twin and earth tails | on ElectriciansForums
Discuss twin and earth tails in the UK Electrical Forum area at ElectriciansForums.net
preston lancs
Hi everyone, i recently had a look at a first fix which has been abandoned and now needs completing. this is a shop premises, with the meter located in basement. shop premises are ground floor and there is a firstfloor flat (no work to do in there). The shop consumer unit is connected to the meter by approx 10 metre length of probably 16mm twin and earth. there is also a 16mm earthing conductor.
looking through the regs, i am under the impresion that tails need to be 25mm. from a loading point of view, 16mm would be ok
interestingly the upstairs flat is also connected to the meter via twin and earth, and i have seen this done in a few flats i have had cause to visit for faults etc.....is it legal? and if so, under what authority/ regulation
thanks for that, i was intending to fit a 100amp double pole isolator with 60 amp fuse as the tails are longer tham 3 metres, just wasn't sure on the legality of anything less than 25mm. matter of interest, i can find reference in the osg which quotes tails must be 25mm, but haven't found anything in the ed17. supppose it must be in there. do you need to quote 16mm as a departure in the eicr?
The OSG seems to have introduce this feeling that tails always have to be 25mm. I always install 25mm on new installations now, but didn't start doing so until I'd used up all my 16mm!
Nope, ....Your all looking at a illustration diagram, and because it's showing 25mm on the tails, now THINK that all tails from a domestic cut-out has to be 25mm!! Nowhere within the OSG, or anywhere else, states or implies that 25mm is the minimum size tails!! You size your tails to the service cut-out installed fuse not to what an illustrative diagram or what's printed on a fuse cut-out cover!!!
To be fair, 2.2.3 does state a minimum of 25mm. but then goes on to reference 1.3 where this is not the case.
In my opinion this is irresponsible.
I think the OSG is a poor publication and following 7671 is a far better method.
I did not buy the latest version until the scheme assessor would not pass me without it. ÂŁ20 wasted.
In the OP's case Table 4D5 applies just as it does to the rest of the installation.
I didn't say that 25mm tails have to be used.....or that that is what I believe, I referred only to the general feeling that this is the case these days.
Well if it does stupidly comes out with a statement like that, gives me yet another reason not to give these OSG's too much credence. But then i don't and never have needed a guide, to tell me what size tails to use...
Reply to twin and earth tails in the UK Electrical Forum area at ElectriciansForums.net
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
