Twin output bathroom downflow heater | on ElectriciansForums
Discuss Twin output bathroom downflow heater in the UK Electrical Forum area at ElectriciansForums.net
Richard Burns
Mentor
Cambridgeshire
Does anyone know of a bathroom downflow fan heater than can be switched between two different heat settings whilst in use.
The customer has asked for one but I feel that exposed switches are unlikely in a bathroom, however I have seen a review that said there was one available by pull cord switching.
All the ones I have found are adjustable at installation but not while in use.
Thanks for your help
If i remember right one of the dimplex heaters has a 1kw and 2kw setting
You could run to that from a double pole master 'on' switch then into a (10amp) 2 way switch to the 1 or 2 kw setting....this switch being placed in the right location...gash but would work
Alternately, talk to a rep and let them find it :detective:
There was one about a few years ago (Argos? iirc) that had a multi-function pullswitch ie first click half power, second click full power but I have seen one for a few years
I think that is the one the customer was thinking about, if it is now no longer available that explains why I cant find it!
Fin, I think I will have to go for the rep option!
Thank you all for the assistance, I have now had another look in the less likely places and come up blank again, I will have to tell them that it is either the auto reducing output, 1kW output only, 2kW output only, or with a timer, or with a thermostat or all of the above! At least it made me find my Electric Centre catalogue!
Too many choices and none the one I want!
Cheers
Reply to Twin output bathroom downflow heater in the UK Electrical Forum area at ElectriciansForums.net
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
