twinflex fire alarm fault. | on ElectriciansForums
Discuss twinflex fire alarm fault. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
M
Michael0703
Hi,
needing some advice with a 2 zone twin flex fire alarm panel.
The panel is showing a power fault which is obviously the batteries as the voltage is only 19volts, but the panel has also shows a fault. See attachment.
  • [ElectriciansForums.net] twinflex fire alarm fault.
Reply to twinflex fire alarm fault. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
