R
redlitchfield
Hi,
I am about to refurbish two attached outbuildings for an old colleague as he wants to use them for his music teaching (one room for teaching space and one for parents waiting room). After deciding it would be too expensive to extend his central heating radiator feeds we have settled on having one wall mounted convection heater (2kW) per room. Each room is 2.4x4.5m.
I'm putting in a dedicated ring for the two rooms and each room will have four sockets in. The way the ring will be run into the rooms from the consumer unit and the heater positions work out that the two heaters are evenly spaced on the ring (9 and 3 o'clock if you imagine a clock face).
Now, the regs mention about "comprehensive electric space heating" not being connected to a ring. I just wondered how 'comprehensive' has been interpreted in the past with regards to the feasibility of the above?
Giving them their own supply is an option but will incur more cost/work/different cu, just thought I'd ask before I break him the good news.
Any thoughts would be much appreciated.
