Spudnik
Hi all,
Went to look at a job today that needs a little fettling.
Set up is.
House (very old) with meter situated on the first floor landing.
From here we have 25mm tails to a dp service block, with two 16mm T&E's, one going to a CU in the same cupboard, which feeds various circuits in the loft conversion.
Second drops down stud wall to the under-stairs cupboard to an old wylex which does the rest of the 'existing' house.
Can anyone see any reason why i cannot replace these with a standard CU with RCD main switch for each one, rather than dual RCD for both?
Much obliged.
J
Set up is.
Much obliged.
J
