Two fuseboard fitted with new installations - i need two certyficates ? | on ElectriciansForums
Discuss Two fuseboard fitted with new installations - i need two certyficates ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
poul
hi
just quick question, i have new installations, and i expect electricial for testing and give certyficate, but i have two fuseboard, i have one supplier head split for both so i need two separate certyficate or its possible put on test results from both for one certyficate ?
thanks
Just test the first board as you normally would, then put the second board on a continuation. The origin details will need to be worst case scenario so I would measure at both main switches etc and record your worst. There would have to be something amiss if you different results though.
Is this one home or 2 flats?
If its 1 home then one EIC and 2 x schedules, if its 2 flats, its 2 x EIC and 2 x notifications to LABC
Are you a registered sparky?
hi
i not yet registered, i am just pas 17th ed electrician, i do domestic installation and som of NICEIC Aprooved contractor certyfited my jobs, but now he go outside UK, so i just get other electrician, and he said i need 2 certyficates. this is two fuseboard for one big house, 1 is 10 way where is all socket, oven, undelfloor heating, and next one is just lights (5 circuits) + mains for smoke detector.
so, it's 1 installation with 2 CUs. that means 1 certificate, with a SOTR for each board.
Reply to Two fuseboard fitted with new installations - i need two certyficates ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
This is an RSS feed of thread: Two electrical supplies and a single immersion element Content of the thread: Good afternoon, new joiner here with...
