Two houses fed of one houses mains - what are my rights. | Page 3 | on ElectriciansForums
Discuss Two houses fed of one houses mains - what are my rights. in the UK Electrical Forum area at ElectriciansForums.net
Coventry
Keeping it brief. We recently had a utility room put in the back of our garage including new wiring and a new mini fusebox in the garage by certified electrician. Few weeks later smell burning from inside fusboard, the copper negative (i think that's right, it was copper with black plastic around it) had overheated and melted. Called the electrician and he said likley as you have exceeded voltage capacity due to dishwasher, washing machine and dryer being on at same time for example. He came round and took the inside fusebox lid off and tightened the wires and said should be ok now but dont use everything at once to be safe. So we didn't. Few weeks later smell burning again from fusebox, its really hot. Except nothing is on. So I decide fusebox is too old as its one the plastic case ones from seemingly when house was built in 1960s.
Electrcian is here today with new RCD board, all going well until he takes the main power feed wire to the fuseboard to change them over. 30 mins later western power guy is at the door asking if we're having work done as next doors power has gone.
Turns out both houses were linked up to the same 60v fusebox in our house, and he said they used to do it like that way back when to save time and money!
So here i am ÂŁ450 down with the current electrician and western power are saying the fusboards need to be separated by western power at no cost to us.
But for me I'm already 450 down for something that turns out wasn't our fault.
As above, the fuse is shared and power branches to your meter and to your neighbour’s installation (via the steel conduit). I agree this has not caused your problem.
Thanks for this as when everyone was saying its well obvious I had no idea where to look. He said something like he has been doing it 20 years and never seen one go through a wall, I think he thought it was somehow connected to our inside walls or something... or maybe I'm making excuses for him
2 types.
1.dual RCD board so the circuitsa re split half on each RCD. downside is if the RCD trips, you lose half the curcuits. aveage cost installed ÂŁ400.
2.All RCBO board. each circuit has it's own MCB/RCD combined so a fault will only disable the one circuit. average cost installed ÂŁ550.
then there's options of Surge protection and arc fault detection both of which will escalate the cost/s.
I've been 'doing it' for 50 years, and I've never seen one go through a wall, but it's right in the centre of his field of vision, and blindingly obvious as to what it must be.
The only other thing likely to be connected like that would be a large 'weed' producing facility.
2 types.
I paid ÂŁ450, I guess its ok but not sure whether I've actually had work done which is verifiable and means jack all when I come to sell. We brought last year and there was no records of it electrics etc. So not sure if we'll be able to use this report thing hes left as proof.
[ElectriciansForums.net] Two houses fed of one houses mains - what are my rights.
there are some glaring errors on that certificate/report. e.g. max. permitted Zs 5.82 for all values of MCB WTF?
main switch 60898??? should be 60947-3
several more that I'm sure someone else will comment on.
2 types.
He did say it will only trip the
anyway, should have bee a EIC for a new CU, not a EICR.
The wiring to our CU is new aswell, nor sure if that actually means anything.
Reply to Two houses fed of one houses mains - what are my rights. in the UK Electrical Forum area at ElectriciansForums.net
