Morning all,
Came across an interesting one yesterday. On a farm, two P1 27.6kw inverters with identical arrays that used to have the same output, since nov2015 one is running about 20% down as i witnessed.
Immediate assumption was that a string was down but string voltages tested out fine, 6 strings max being 723v and min being 695 in changeable conditions.
I tried swapping the arrays and managed to move the low output to the other inverter which indicates to me that it is an array issue but with the strings testing out ok i'm not really sure where to look.
No Fault codes or issues indicated on the inverters.
If anyone has any ideas i'd be greatful to hear them
Thanks, hope your 2016 is going well!
