two motor star delta | Page 2 | on ElectriciansForums
Discuss two motor star delta in the UK Electrical Forum area at ElectriciansForums.net
dubai
hi guys i have an issue with one of two motor running star delta for a concrete mixer one motor is pulling out more current than the other one almost 10A difference (1st=39 , 2nd=48) knowing that the 2nd is rewinding both motor are same company
Method of starting I presume.
Common in all of the concrete plants I worked at for their mixers. Until we started upgrading to VSD control.
Agree, bot the OPs fault his English is a bit confusing wonder what I sould be like speaking his spoken word, did a good job I thought, just got myself all tied up, must be an age thing on my part.
My guess, if the winding's test out ok and are balanced. (Test from the starter cabinet first, you'll find cable faults too that way). Then it will be mechanical failure, likely a bearing on the mixer itself or in the motor.
Quick check, disconnect the motor and run it without a load, check the current is equal an within a sensible range on each phase.
Reply to two motor star delta in the UK Electrical Forum area at ElectriciansForums.net
I got this all wired in and working thanks to the help from James, absolutely top man. Do have a small issue with current imbalance atm, L3...
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
