two outlets to one? | on ElectriciansForums
Discuss two outlets to one? in the DIY Electrical Advice area at ElectriciansForums.net
Do NOT do this. It is fun to make things out of junk but it's no excuse to cut corners with electrical safety. Any cable with two plugs is dangerous, whether parallel wired or hot-to-hot like this, as exposed prongs can be energised. The are are other safety issues with this project too, so do yourself a favour, buy a safe welder from the tool store, and if it needs 240V get a proper 240V outlet installed.
Reply to two outlets to one? in the DIY Electrical Advice area at ElectriciansForums.net
I found out the answer from another forum...here it is, yes This will be your neutral for the receptacle. Add a pigtail and connect to silver...
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
