Two Ovens, One Cable | on ElectriciansForums
Discuss Two Ovens, One Cable in the UK Electrical Forum area at ElectriciansForums.net
Electron
Altrincham, Cheshire
As my customer didn't know what double oven they wanted I installed a 40A MCB and 6mm twin and earth. When I returned for the second fix they have installed two ovens. One is a single oven (3.65kw 16A) and the other is a microwave/grill/oven (3.45kw 16A). So what is the best way to connect both with one supply? The first idea I had was to use a 45A DP Switch and wire both ovens to this. Ideally, I would like to isolate each one separately. Has anyone any suggestions?
I tend to wire these on a socket and plug top (single socket for each) as one you apply diversity the loading usually drops to below 10amps. Don't know what model you have though could be a particular large single oven ??????? This would mean some kind of joint as sockets won't take two 6mm obviously lol
MK sockets will allow x2 6mm cables
I must say I had exactly this situation a few weeks ago, and I put 2 DP switches off the single 6mm cable, one for each oven. However, afterwards I thought it was probably unnecessary, and as Murdoch says a single switch is fine. You have to consider what the switch is for, it only to turn the oven off in an emergency. If one of them fails an electrician will have to disconnect it properly anyway, they are just switches not isolators.
Hi Simon - agree above - one switch and a double outlet gets my vote :)
45 Amp Dual Appliance / Cooker Outlet Plate - https://www.tlc-direct.co.uk/Products/AA45DCOP.html
[ElectriciansForums.net] Two Ovens, One Cable
I take your point but would like to add would never use a plug and socket on anything like a hob or double oven ect just single ovens and combination microwave as these tend to either come with a plug or a piece of 1.5 flex fitted.
Don't wanna sound like a --- but am new here and don't you guys thinking I'm some kinda cowboy yey haw lol
Reply to Two Ovens, One Cable in the UK Electrical Forum area at ElectriciansForums.net
Thanks so much for all the responses guys! It seems that what I'm planning is nothing unusual or regs-busting. I'll hook it all up and have a...
Just an update for anyone interested, I got another rod in outside today, which has lowered the Zs db to a more healthy 53ohms. The oven elements...
