Two PIR two light setup | on ElectriciansForums
Discuss Two PIR two light setup in the UK Electrical Forum area at ElectriciansForums.net
E
Eclecticism
I was wondering the best way to connect two of these http://www.free-instruction-manuals.com/pdf/p3421029.pdf PIR sensors to activate two 230w halogen lights at the same time. Firing up two lights off the one sensor isnt a problem.
Its going to go fused switch from the mains to act as on/off to a two that will act as PIR/always on to the first PIR. Is it as simple as just wiring the supply to the supply and load to the load of the PIRs?
Fitted a few of them and they aint bad. Wiring box could be a little bigger though...
Thanks for confirming Mark. Last night I decided to look at different setups, inclding an IQ transmitter setup, but I got totally sidetracked and started reading forums where they were modding PIR's to work together. Then I read a few, what seemed strange to me, setups. It left me wondering if there was some sort of 'trick' to it.
Reply to Two PIR two light setup in the UK Electrical Forum area at ElectriciansForums.net
How did it go?
