Two PIRs for one light? | on ElectriciansForums
Discuss Two PIRs for one light? in the Australia area at ElectriciansForums.net
R
rantoftheday
Is it possible to wire up a lighting cicuit so that there are two PIRs controlling one light so that if any PIR is activated the light comes on?
And if so does anyone have a wiring diagram for such a system?
Yes common the line on one side and common the SL on the other. i.e. wire them in parallel to each other.
Pretty picture:
[ElectriciansForums.net] Two PIRs for one light?
2 core feed neutral to the fitting the 3c between fitting and first pir and to second, depends on how your wiring it the picture above works (1 core too many) but you lose your permanent feed to the fitting which you may need unless thats the complete circuit mentioned and it isnt an emergency light, unless you use a 3core from pir to fitting shown in the drawing to continue the perm feed then problem solved.
You could have a lot more than 2 PIRS if required, ive installed like this before within a commercial property, large room with 3-4 entrances
Take a 3core and earth from any light/fitting to the first pir then wire to the next and on and on and on.....
No matter which PIR is triggered it will send a switched live back through the 3core and other PIRs and switch the lights on
do you just add another feed on to the swithced live if you want a permnenant light on????
not sure what you mean there looking at the updated diagram the lamp will only have a switched live via either PIR but if this wasnt the end of the circuit you would need a 3 core from the pir to the lamp continuing the permanent feed say to the next room etc (obviously you wouldnt need a 3 core between rooms/differently switched circuits only a perm feed and neutral).
Do you mean adding another switched live from a switch onto the same switch wire to bring the lamp on like an overide switch to keep the lamp on? cant say ive ever installed an override switch to keep the lights on but have to kill the feed to the pir whenthe light isnt required, so if someone leaves the switch on the pir will turn off and then the switch can be turned off when the lights arent needed for whatever reason
The diagram here is "feeding the switch" and is not really planned for an internal lighting loop in system, but if you were running this as part of a loop in system then you would loop in from the PIRs not the lamp (waste of cable).
You can have a manual override (not really allowed now for new outside lights, must be time and light controlled) and you are really just adding another switch but instead of a PIR use a manual switch; as mentioned above just more switches in parallel, even if the PIR operates it will not make a difference, just crate parallel feeds to the lamp.
diagram a bit messy now but..
this shows a couple of manual overrides.
Reply to Two PIRs for one light? in the Australia area at ElectriciansForums.net
Commonly known as double knock, some pirs have a latch on time delay for a few seconds, giving time for the 2nd one to activate .
The existing wiring shows both brown wires into the same terminal. One should be in the terminal it is in now and the other in the terminal next...
