G
graham123
am doing a pir at a school which has a terrapin, the supply to the terrapin is a 3core 16mm, single phase. Question is somthing sticks in my mind thinking that externally supplied bulidings, sheds, garages etc used to require an earth stake?? Cannot find any answer to this in current regs. Im presuming as long as the earth going to the terrapin is of the same size as the equipotential bonding in the school its fine?
Also how do you calculate the maxium demand load on a PIR?
THanks
THanks
